Re: 1983 90hp evinrude ignition problem
Just read your previous posts, and am going to now assume you have access to a DVA meter.
Have you tested the trigger resistance and DVA output on all 4? They should read as follows.
Wire Color : Check to Wire Color : Resistance : DVA Reading
White wire : Purple : 35-55 : 0.6V or more Connected
White wire : Blue wire : 35-55 : 0.6V or more Connected
White wire : Green wire : 35-55 : 0.6V or more Connected
White wire : Pink : 35-55 : 0.6V or more Connected
Leave the orange wire from you PP connected to the corresponding coil, and check the DVA output. If you're not getting at least 150V, there are issues. If it is low, disconnect the coil, and wire in a load resistor of the appropriate size. Now re test. If the reading is now at the 150V, your coil is shot. If you are still below the 150V mark, your PP is likely shot.
