Re: What is the easiest way to test a carb.
Just to start, I would test the spark and compression on your new motor. The spark should jump the 7/16 of an inch gap with a bright blue ZAP!! and the compression should be even on all cylinders (within 10 percent) and around 100psi. Also, being that the motor is new to you, I would bath and rebuild the carbs, as well as rebuild the water pump.
That being said, in regards to your question, you could 'read' the plugs for one. A few of the 'reads' are listed below.
• Dry and powdery, and gray or coffee-colored: good.
• White: too-hot plug.
• Black: too-cold plug, or low compression.
• Wet and carbon: mix too rich, too-cold plug, bad fuel-oil mixture, bad oil, worn rings, bad ground on ignition.
• Water: water in fuel, blown gasket.
• Eroded: overheating, too-hot plug, bad timing, bad water pump, clogged water intake, overloaded.
• Carbonized and worn electrode: worn plug (replace it).
• White or grey insulator, maybe blistered: overheating, maybe from loose plug, lean fuel, wrong heat range, bad timing.
• Black with heavy fuel and oil deposits: seized piston rings.
• Dry or wet fouling: too rich mixture, too much slow-speed use, choke overuse, electrical trouble, too cold plug heat range.
• Black with soot: restricted air flow, too-rich fuel mixture.
• Molten metal on plug: detonated piston (need rebuild).
