could anybody suggest good places to find parts for a 96 4.3lx? i'm specifically looking for a cam and lifters and a block, but need various others as well. used parts are fine, as well as used complete engines.
thanks
thanks
thanks
my problem with that is i was told i need to use my original cam, but it's pitted from having water sitting on it. thought about trying it anyway, as it's very minor pitting, but unsure
My life revolves around Part #s,.... You'll have to Check...are these the same pistons as a 350?
For Obvious reasons,.... NO.....can i use my plastic 6 bolt timing cover on an engine with 10 bolt holes?
Nope,... But Why would you even Want to..??is there any reason why i cant use new lifters on an old cam?
Ayuh,.... They're All interchangable,... But there's always fitment issues to go along with that....are the heads the same or interchangeable?
is any of this worth it if I can find a rebuilt engine for $1600.00(long block)
reason i asked bout the timing cover is my motor had the plastic cover with six bolts, but when i removed it, there is ten holes all tapped on the block.
my heads have 6 holes for the intake, including the two in the center(almost)
I seem to remember pistons for a 350 are the interchangeable, but wasn't sure. will try to find the same style.
the casting number on my block is 196, i dont remember the casting number on the balance shaft, but i was told this specific combo was used from 92-97. it does however say vortec on the rocker covers. any other way to tell if it is actually a vortec?
