boatsrwerk
Thread starter- Joined
- Feb 26, 2008
- 7
Hi guys,new kid on the block here.I have been reading some of the prior posts & think I know the problem but want to run it by you guys to see if i'm headed in the right direction.I have a 1981 Seaswirl w/5.0 gm & omc 800 mech shift.the engine stalls when you shift into forward,could this be from a sticky/worn shift cable in the lower unit?The seloc book says if it shifts stiff @ the converter box with the prop turning it's the cable.How easy should the lever move by hand?thanks Dana
