Hello,
This is the first time that I have ventured into re-ringing an outboard engine. It is a early 1980's vintage 7.5 hp Johnson. I have it all torn apart, honed the cylinders and ready to put the pistons back in. I have a few questions:
How do you assemble the roller bearing so that they do not fall all over the place. Do you glue them in with grease?
What type of sealer do you use to seal the halves of the crankcase? There is no gasket but it appears that there was some type sealer between the halves. Just wondering what type I should use?
Does anyone know the torque specs for the connecting rods and the crankcase bolts?
Thanx for your help and have a great day.
Rob.
Rob.
