Key Switch Bad
TIDECRAFT
I have a 77 115 evinrude i am getting no juice to my starter at all in the past it was hard to turn key is it bad or how do i check it? i turn the key on and it does nothing the choke still works but no juice to starter
flabum
Re: Key Switch Bad
Check for voltage at the engine. The yellow/red wire at the solenoid should power up when you turn the key. If it does not, then it could be 1) wiring 2) nuetral safety switch 3) key switch.
jtexas
Re: Key Switch Bad
clean the wiring terminals and posts on the solenoid, make 'em shine (use sandpaper if you have to). don't forget the ground connection on the engine.
Keyswitch terminal "S" should be hot with key turned to start, or test for continuity between "S" and "B". Neutral safefty switch should be closed with shifter in neutral, open in gear. Test yellow/red for continuity between keyswitch and main wiring harness plug.
Re: Key Switch Bad
could also be the inline fuse near the solenoid.
ezeke
Re: Key Switch Bad
That diagram may not be the right one for your control, but nevertheless, if the choke is working, it is not the fuse. Does your choke work by a toggle switch?
I would guess that the neutral safety switch is loose or shot, or that the ignition switch should be replaced.
You can check everything with an ohmmeter without dissassembly.
TIDECRAFT
Re: Key Switch Bad
I tested s & b had nothing the fuse is ok where is the neutral safty switch located?
TIDECRAFT
Re: Key Switch Bad
Replaced Key switch and nuetral saftey switch works like a charm thanks guys
