Re: 79' 85HP Johnson starting and running prob.
welcome to iboats.
fuel line holding pressure? tank vent clear?
in the driveway your motor will idle fine on 3 cylinders but the water puts backpressure on the exhaust.
first, compression test.
second, cylinder drop test - engine idling, pull then replace the spark plug wires one at a time (use an insulated or plastic tool to avoid shock). if RPM's don't drop noticeably, that cylinder's not making power.
then check for spark, remove spark plug, reattach it to the boot, hold it against the engine block and look for a spark while somebody turns the engine over.
no compression gauge? skip that step.
all cylinders pass the drop test? get a spark tester (couple bucks at autozone), set it for 7/16", look for a sharp blue spark.
good spark all around? rebuild carburetors.
