Alarm sounds, are they different sounding.
w2much
1995 150 Ocean Pro. Do different symtoms cause differnt alarm sounds? Does overheat sound the same as fuel flow resrtiction and low oil? Thanks.
rickdb1boat
Re: Alarm sounds, are they different sounding.
Fuel restriction and overheat will be a solid alarm. Low oil will be intermittant...
HighTrim
(VRO Horn Warnings)
(J. Reeves)
1 - A steady constant beep = Overheating - The V/6 engines, possibly some others, have a fuel restriction warning which is also a steady constant beep.
2 - A beep every 20 or 40 seconds = oil level has dropped to 1/4 tank. (Late model engine = Every 40 seconds)
3 - A beep every other second = VRO failure, air leak in oil line, oil restriction, (anything that would result in a lack of oil being supplied to the engine).
