Backyard Mechanic - Finding Voltage Leaks
SV1000
In the past, I have taken a spraybottle with water and misted the distributer and ignition wires on my old Chevy started it up in the dark; it was easy to find where bad plug wires were allowing spark jump to the exhaust manifold or other ground sources.
Will this work on an OB motor?
5150abf
Re: Backyard Mechanic - Finding Voltage Leaks
You would think,an ignition as an ignition so it should work.
When I read the headline that was what I was going to suggest.
It certainly can't hurt anything.
some times you don't need the water. just dark.
SuperNova
I usually just lick each wire until I find the voltage leak:eek:
seahorse5
Windex works great !!!!
R.Johnson
Why not just a test lead with a probe end, gounded to the block?
