Evinrude Gearcase leak
kmchugh
I just bought this 1968, 9.5hp Evinrude, and after changing the gearcase oil, it seems to be leaking. The oil is coming out a weep hole under the cavitation plate. If I wipe if off and come back a day later the drip, is there again, however each time there is less oil. Does this mean if have a cracked lower unit? I'm not sure the oil leaking is actually 90 weight oil. Another point of interest, is that it may have been shipped upside down.
PmDavis300
Re: Evinrude Gearcase leak
might be the unused fuel/oil mix? thats what happened to me. its leaking out above the gear case?
ezeke
If it is coming out of the drain hole, it could be either a spill, or a cracked housing, but probably is neither one.
The spent oil from the engine runs down with water and exhaust and out the back end of the gearcase. It partly fills the midsection to cool and muffle the exhaust. When the water runs out, the oil runs slower.
kmchugh
It's good to know that it's not definately a crack. The previous owner may also have fogged it, and now like you say the excess oil flowing out. One other fact I didn't mention earlier was that the grease in the gearcase looked milky. So I guess I'll have to keep an eye on it.
Thanks for the feedback!
ezeke
The 9.5 unit is like most gearcases, the water usually gets in through the vent and fill plugs when the nylon flat washers fail. It really is better to replace them whenever you open the plugs. I finally started buying a bag of 50 here at iboats, just so I would have them around. (Sierra 18-42481-9)
The 1968 9.5 is easy to reseal if you ever have the desire to do it. The hardest thing is getting the screws loose that hold the skeg. I have always had to use a hand impact tool to get them started.
There are two different seal kits for 9.5 gearcases; 1967 and back (Sierra 18-2682) and 1968 and up, (Sierra 18-2683). The problem is the whole drive is interchangeable so you have to be sure which drive you have. Fortunately, the kits don't cost that much.
http://www.iboats.com/mall/partfind...d_row=7&keywords=18-2683&**********=380337163
cc67
"I have always had to use a hand impact tool to get them started."
Me Too. That is why I have started using allen head screws when I reseal a lower unit. Usually the original ones get too buggered up to reuse.
ezeke
Where did you find them?
Evinrude Boater
"That is why I have started using allen head screws when I reseal a lower unit. Usually the original ones get too buggered up to reuse.
Oh, I like that. My 40 hp is all apart now so maybe a good time to replace the screws. Why didn't they just use hex bolts on them?
cc67
Any good hardware store should have them. The allen heads are are the same head size as the slotted ones so they will fit in the in the skeg. The ones I use are just a tad longer than stock so they grab a few virgin threads. I believe they are 1/4 x 20 NC.
ezeke
Just for reference, I found a good on-line source here in Weymouth MA for hardened stainless socket (Allen) screws.
Stainless socket screws- copy the link without the quotation marks: "http://www.boltdepot.com/dimension.aspx?cc=13&cs=71&cm=6"
bearddd29
ive got an 18 hp johnson and does the same i think its old unburnt oil fuel mix
