OMC Outdrive...I took it all apart - Need parts
rotor_av8
'68 Seabird 307ci SBC OMC Electric Shift (looks like a long shaft)
I know the saying "If it 'aint broke don't fix it"...BUT...Fearing a breakdown in BFE (or swap the E with an O for ocean if you prefer) I decided to take apart my entire outdrive because the boat is new to me. :eek: WOW it is a good thing I did.
Everything is in parts now on my bench after a day of fiddling. All except for the foreward gear and coil in the lower case which requires the special tool to turn the driveshaft while holding the pinion nut with a 1 1/16" wrench. The gears all look great and shift so I'll leave this part in.
My upper gearcase casing has a crack/hole and my propeller shaft has a big old crack in it as well. A nice spiral crack that means torque to me if it's like an axle shaft. Probably a prop strike....may explain the perfect prop with fresh black paint. Hmm...a real jerry rigger had his hands on this one. Put a new prop on a severly cracked shaft for personal use....I think even the brave dare not. :eek:
The gearcase was patched on the side with what appears to be bondo then re-painted....seriously. It can be scraped off with a screwdriver forming a crusty powder. Looks like a fix-to-sell not a fix-to-use solution. "Nice...Job!!"
-quoting me when I found it. :mad:
My casings got contaminated with water and left the fun film I'm sure you are all familiar with. How do you wash this out? Do you run the unit with fresh oil then keep changing it with new untill it is clean or is there a special way to clean it all out? I'm considering degreaser then electronics cleaner or brake cleaner followed by a couple days of evaporating to get the moisture out.
I am looking for the upper gearbox or just the casing for it. I am also looking for the propeller driveshaft. It looks like these will work from a v-8 model electric shift from 64-77 or so. If you have these let me know through a PM. An entire outdrive would be useful too....short or long shaft electric shift. E-bay has them but i'm looking for a cheaper option.
Who has or sells an entire re-build kit for the electric shift's? ...gaskets and o-rings...I can make gaskets and buy o-rings but a kit would sure be nice.
BTW after a 1/4 turn on the prop a large c-clamp worked awesome to slide the prop off. I used rags under it but the pic (will add pic later) is just to show how it fit up.
http://i245.photobucket.com/albums/gg62/killiase/SS850674.jpg
http://i245.photobucket.com/albums/gg62/killiase/SS850662.jpg
http://i245.photobucket.com/albums/gg62/killiase/snapring.jpg
http://i245.photobucket.com/albums/gg62/killiase/SS850694.jpg
http://i245.photobucket.com/albums/gg62/killiase/SS850696.jpg
http://i245.photobucket.com/albums/gg62/killiase/SS850699_small.jpg
http://i245.photobucket.com/albums/gg62/killiase/SS850698_small.jpg
-Rotor
Coors
Re: OMC Outdrive...I took it all apart - Need parts
'http://www.sterndrive.info/[/url]
whywhyzed
Banned
ziggy
ran accross this. i've no idea if it helps. but looks like omc stuff maybe...
"http://www.marinepowerservice.com/BoatingStore/browse_parts1_kel.cfm/parent_cat/443085/parent_cat1/450438/parent_cat2/450441.cfm"
rotor_av8
how many bolts hold the top cover onto your outdrive, 4, or 5?
5 is this significant? I have been wondering if my outdrive is the same year as my boat.
Lyndy
One item that is somewhat unique on a 1968/1969 is the actual shape of the Boot. It is pretty much so round. The Tilt Gearbox is a little different also.
rotor_av8
Mine looks like the one you picture there.....only it has been painted black.
whywhyzed
Banned
Lyndy
Yeah, my was painted also. It is White now. Although your Boot is not Round, the shape of yours was one of three boots used for that year. 1969 model used just 2 of them. The one not used is the one below that has a Square Frame. As mentioned in a previous email, parts can be generally swapped out. Beware though that some of the parts look different and have seperate part#'s. Having said that, my drive had an Exhaust housing same yours. I replaced it with a 75/76 model that was different in appearance (sharper looking) and it fit just fine. So there is a buyer beware. As you continue to refurbish this drive just research it before you just buy.​
Below is what mine looked like when I first layed eyes on it. It is about a 1974/75. Look Familiar?
Can you believe the previous owner thought Muffs would work on this unit?
badman
Yeah, my was painted also. .​
YOU ARE A DIAMOND! THANKS TO YOUR PICTURE (SCREEN GRAB) F BRP PARTS, I HAVE TRACKED DOWN MY LONG SHAFT DRIVE AND SEALS USING THEIR SIT FOLDER SYSTEM. IT IS UNDER THE 80 FOLDER 1968.
THANKS!
lowriderboat
OMC Upper Gear Case 382160 185-210HP.jpgHello Forum - first post, looking for some help. I have a 1968 OMC stringer, Electric Shift, the upper gear case leaks, so I am looking for parts for this particular unit, but the only numbers I can find anywhere are on the upper gear case, left side, small circle with the numbers 382160 185 - 210 HP. I am looking for a water pump case (only one is deformed?) upper gear case bearings and seals with which to rebuild the unit. I did purchase a 1965 Lower Unit, but when I opened it up, it too was shot, so now I have my 1968 and a 1965 lower unit, both in-op. So, if anyone can determine by the numbers 382160 what parts, or even where I can find a repair kit - I would be most appreciative.
Nivekt
View attachment 164618Hello Forum - first post, looking for some help. I have a 1968 OMC stringer, Electric Shift, the upper gear case leaks, so I am looking for parts for this particular unit, but the only numbers I can find anywhere are on the upper gear case, left side, small circle with the numbers 382160 185 - 210 HP. I am looking for a water pump case (only one is deformed?) upper gear case bearings and seals with which to rebuild the unit. I did purchase a 1965 Lower Unit, but when I opened it up, it too was shot, so now I have my 1968 and a 1965 lower unit, both in-op. So, if anyone can determine by the numbers 382160 what parts, or even where I can find a repair kit - I would be most appreciative.
If you need help with your boat it's best to start your own thread, not tag on to a 4 year old one.
