Re: 1990 90 HP Johnson Overheating
Does the warning happen at all RPM's or usually only at higher RPM's?
The problem is, the overheat warning and the fuel restriction are both a constant tone. Will pumping the primer bulb cause the buzzer to stop, how about backing off on the throttle?
If it is in fact overheating, you will need to look to the cooling system. If you cannot hold your hand to the water jacket for a good 3 count, it is too hot. A infrared heat gun would be best to measure the temp. When was the water pump last rebuilt? If it has been a few years, it is time. I personally do the t stats at the same time, as I like to take the time when the lu is down to flush water or compressed air up the water line to the t stat housing, then replace the t stats.
If it turns out to be a fuel restriction, I would start at the tank vent and anti syphon valve, and work out from there.
