Older model evinrude
crappie king
I was recently given a older model evenrude by my aunt. It is either a 50's or early 60's motor. I ordered one of those old gas tanks off of ebay because it did not come with one. Motor was my uncle's before he passed away. It ran 3 years ago the last time he used it. My question is on the gas mix what should I mix regular motor oil or a evinrude/johnson mix and what the ratio should be.
ezeke
Re: Older model evinrude
When you find the model number on the engine, you should follow the BRP/Evinrude general guidelines found here for the age of the engine: http://www.evinrude.com/en-US/About.Us/FAQ/Oil.Fuel.htm
Use TCW-3 rated oil or better. Many have gone to synthetic blends or full synthetic TCW-3. The synthetic oils tend to smoke less and produce less carbon.
You may find the Engine FAQ forum helpful, especially the thread about "Awakening......"
http://forums.iboats.com/showthread.php?t=158086
Check model numbers here:http://web.archive.org/web/20011208133609/www.evinrude.com/docktalk/modref/evmodyr/evmodel.html
Joe Reeves
Model number should be on a plate attached to the port (left) transom bracket (bracket that attaches engine to boat). If you have a problem finding the ID of that model number, list it here.
jbjennings
If it's the pressure 2-line tank you can almost bet it's a 24:1 ratio, but it could be 16:1. You'll have to find out the year and horsepower as already said.
How about a picture? (I always like to see 'em)
JBJ
crappie king
ShareLandingReg.jsp
Not sure if this link worked still looking for the model number however found the serial number.
samo_ott
Is it a metal hood or fibreglass? And is it a 1 line or 2 line tank? As JB said, if it's a 2 line then it's 24:1 high chance.
