trim sender wire plate bolts broke
snake91876
i was replacing trim sender and limit switch and went to remove grommet plate in housing where wires pass through the transom and the bolt on the bottom broke off , now what should i do i might can tap but its kinda cramped.
CharlieB
Re: trim sender wire plate bolts broke
Sorry, I don't know of any easy fix for this one!
Pull the drive, pull the gimbal ring LOTS of penetrating oil very carefully punch a center and even more carefully drill with a left hand twist bit and hope it snags end backs out.
(fingers crossed for you)
snake91876
is this part underwater or can i use one bolt and seal it good
