Question on 50's TD and TN lowers
Scaaty
Is a late 40's TD L/U the same on the early 50's TN's?
I just can't remember...thanks..
Chinewalker
Re: Question on 50's TD and TN lowers
Nope, and they won't interchange - bolt patterns are different between the direct drive TDs and the neutral enabled TNs. The TN's used a rubber star style impeller on the driveshaft, while the TDs used a plunger type on the propshaft...
Scaaty
One I got here has what looks like a 2 inch spring where the D/S goes just before it goes into the guts (rest is gone..impeller.)
That a TN Scott?
Just took a pic..post in a sec...
F_R
The TN has a neutral clutch--the spring you see. The TD is direct drive--no spring.
Scaaty
Thats what I thought. This one does. Just could not remember where the spring was on the TN's..thanks!
Scaaty
Heres a pic in case someone else needs it..and to make sure we are on the same page..
