EricDickerson
Thread starter- Joined
- Mar 11, 2008
- 2
I purchase this outboard not running. I went ahead and removed the flywheel to inspect the points. To get my puller on the flywheel, i had to remove the bolts from the hub. Only problem is, opps, i forgot to reinstall the hub bolts before tightening the crank nut and in spun on the flywheel. There are 8 bolts, so 8 different ways the flywheel can go. My question is, is there anyway to tell on these motors. I tryed 3 different position. The engine will run now but not good. Are there any timing marks that i am missing. Help would be greatly appreciated. I only want to pull it apart one more time.
PS. This engine looks to have been used very little so i dont believe any of the linkages have been tinkered with.
