Johnson Lower Unit Drain/Fill O-ring
Salmonseeker
Hi Guys,
I noticed in my repair manual they recommend to replace the drain/fill and oil level plug seals every time I replace my oil. DO you guys actually do this every time?
I have never done this in the 3 years I have owned my motor so I thought it might be overdue.
I went to the dealer and picked up the parts. The drain/fill screw has a white nylon washer that is used to seal and the oil level screw has a small O-ring.
The drain washer appears to be correct but have a question about the oil level O-ring. I was given a plane black O-ring that is a slightly different size and completely different colour than the one I removed.
The one I removed is a orange colour and does appear to be squished into flatter shape. Does the colour of the O-ring make a difference? Are the black ones okay to use with lower unit oil? And should the O-ring be flat or was this caused by the pressure the oil level screw had on it and squished it?
I know a lot of questions about a simple O-ring. I just want to be sure, I don't want to waste a second when spring finally arrives.
Re: Johnson Lower Unit Drain/Fill O-ring
they squish, thats, why you change the everytime you remove the plugs. # 1 place for water intrusion.
R.Johnson
Some plug's used O-ring's, others' gaskets', use the correct seal.
Salmonseeker
I will definitely replace them.
Does the colour of the O-ring mean anything though?
I am assuming the different colour means a different material. Is a standard black O-ring from a hardware store acceptable to use if it is the exact same size?
F_R
Color counts. With some effort, I suppose I could look up that orange one is. A more direct answer is yes a hardware stor o-ring is fine IF it is Buna-N (Nitrile). Most are, but it doesn't hurt to check.
rjezuit
Orange is usually silicone. You can use BUNA-N, or Viton they will both work. Stay away from EPDM or neoprene, they cn get degraded by mineral oils. Rick
Salmonseeker
Thanks for all the fast replies guys,
I never really thought of all the different materials that a simple O-ring can be made from. I did a quick search and found some charts that show what type of O-ring is compatible with different fluids. Interesting. http://www.allorings.com/compatibility.htm or a simpler version http://aceglass.com/oring.html
The ones at the hardware store were not marked but they do look identical to the ones at the boat shop.
