Old engine, hadn't run in ages. I cleaned out the fuel pump bowl. Then the carb as best I could without a kit, and got the engine started and it seemed to run pretty well in a barrel with water.
Took it out on the bay today, and whenever I opened up the throttle, it would go fast, then in about 10 seconds, it would REALLY lag, and almost die, then go with power again. If I choked it when it was dying, it was no help, so I'm guessing it's flooding, but not sure why throttling down let's it just keep running.
If I throttle down to idle or just above, it keeps running fine.
I've tweaked the high and low speed jets, but haven't been able to cure this.
I'm assuming it's fuel, vs. spark/coils/ignition, since it will run at full power for a short time, and will do it again within seconds of slowing down.
I plan to find/get a carb kit for it (but the float and needle valve looked great, no indentation in needle valve tip, and tip was still soft), and clean it out thoroughly, but wanted to see if anyone had any other suggestions on curing or diagnosing the surging problem.
