How to fix this.
TheWoodCrafter
Here is what I am finding under some of the spiders cracks.
Most are just in the gel coat and I am grinding them out, but some are
into the fiberglass. The holes show up after I grind through the gel.
How should this be repaired?
ondarvr
Re: How to fix this.
Those areas need to be ground down into the glass and for best results all the cracks should be removed, then re-glassed, but that's not always possible. If you don't re-glass over them it won't be long before they're back.
TheWoodCrafter
So I guess you are saying grind out enough material to add a layer of fiberglass over this so it flushes out with the rest of the surface.
oops!
yeah....
fix the way rvr says....
the cracks are called crazing.....and they are a real pain in the .....
uasually caused by impact or stress... most older boats have them
TheWoodCrafter
Thanks guys, I was afraid this was going to be a pain to fix.
