stringers and PL polyurethane adhesive
stefcia
Hi guys.
just wondering - it will be enough strength to use PL Polyurethane adhesive instead epoxy peanbutter, to glued stringers to hull (light grinding + accetone wiping) then glassing them with epoxy +cloth+epoxy mat? Gap between hull and stringers will be 1/8 -1/4''
PL seems to be enough flexible and has power to keep stringers in place then epoxy glass will do rest.
ondarvr
Re: stringers and PL polyurethane adhesive
The only thing the PL or anything else used under the stringer is doing is holding off the hull, so it will be fine. Some people just use a strip of foam.
oops!
hi welcome to i boats.....
pl is under rated in boat building........
there was a simmelar question just asked on another thread......
so....hang on.....the team is on it....:D
cheers
oops
rockyrude
The PL will work fine, it's epoxy + mat epoxy + woven roven at least twice for stringers.
i use PL 100% poly all the time. easy to use.
erikgreen
Actually if you're using poly you generally want a mat/roving/mat/roving layup at a minimum, using something like 18-20 oz roving.
With epoxy, you can just do roving/roving. You don't need the mat.
That said, I just did my stringers with biaxial stitched to mat using epoxy. Two layers of 1708 (17 oz. with 8 oz mat) then switched accidentally to something like 30 oz biaxial with 8-ish oz mat. This is in a 20 foot boat.
Erik
drewmitch44
That stuff is great!!! Someone said its underrated and they are right!! Lets just all keep hush hush about it though. Shhhh! If the manufac heard this the price would jack up! Thats what im going to use to bed my stringers and also my transom. Then im going to glass it all in. Remember Shhhhh! LOL
stefcia
Thanks. progress in fanny job. stringers ready, hull ready, epoxy+reinforcement on the way, waiting for better weather. Any of you used uscomposites epoxy? Seems like chippest one.
erikgreen
That's what I use all the time. Good stuff, although I may try the MAS products just to support iboats a lil.
Erik
Coors
I bought and used MAS locally to rebuild my stringers.
Cheaper, strong, and un-cured clean up involves that expensive, rough on the skin---white vinegar.
SuzukiChopper
3 years ago when I did the transom, stringers and deck on my boat I used PL. Used it to bed the stringers, used it to glue the transom pieces together (spreads just like peanut butter!) and used it to glue the deck down. Worked great!!
If the price starts to go up on the stuff when I get to my next boat, I'll know where to place the blame ;)
Marcq
Yes, that's very good glue, the thing I like about it is that it is slow cured, giving plenty of time to adhere to whatever . My leaning post is glued to the deck of my boat, NO screws. But don't leave it on your fingers because it will take weeks to take it off
Marc..
yes it does. i keep acetone in the shop.
erikgreen
What prep should I use bonding this stuff to epoxied wood? Scuff and acetone?
I picked up four tubes off the Concrete/crack sealant yesterday. Gonna glue my deck down with it...
Erik
Coors
I think I would ask the company, as concrete sealer may be different.
stefcia
Thank Marq and T-Daddy. Ihave learned it in hard way, some parts of my fingers ..... dirty.:eek:
oops!
Erik
im gonna order lots of stuff from i boats....
im a real shop local kind of guy......but im not going to order from the dealerships.....:eek: :eek: :eek:
because i boats does not charge for this forum...they have earned my business.......i dont care if it costs 10 bucks more !...but in most cases...great deals
.......now we just gotta find some large company pro sales rep to sell glass supplies to i boats...!!!!!! :D :D....(inside joke)
but seriously guys....order what ever you can from i boats.....without them giving us this forum....we would be lost.......lets give them the business !
cheers
oops
erikgreen
I believe the surface prep is the same... the concrete/crack sealer is the stuff that's basically identical to 5200... stays just a bit flexible when dried, and doesn't foam up when used.
/shrug
