Took the carbs off my 95' 90 hp ocean runner again to give them a more thorough cleaning. I think the float level is wrong per the manual; however, it only says adjust it...not how? The video guy uses a hammer i think. The little piece of metal holding the needle in place on the bottom carbs seems worn out. I put them back on anyways just to see if I could tell a difference.
With new spark plugs it fired up fine and ran smoother for about a minute. Then backfired several times and died. Tried to start it again and it blew a smoke ring, it was smoking pretty good while started too. Pulled the new plugs and they were wet and black. I will fool with the needle valve again to hopefully get the right mixture. Also, in layman's terms what does 30-35 lbs pressure mean when tightening the high speed jet? Really tight???
Another question.............how important is it that the airbox be clean? I'm guessing fuel can get dirty in there and then re-circulate and dirty the carbs again??? I don't really know.
Lastly, I've been putting 93 in the tank, I'll change when I get a chance............could this cause the excess smoking??? Or does it not really matter.
All in all, completely new to this, so thanks for your help.
