islander46
Thread starter- Joined
- Mar 27, 2008
- 7
My Mercrusier in my 1972 (?) Reinell 18' speedboat with a Mercruiser 120 HP out drive has a mystery problem: Starts and runs great. After leaving the harbor, it runs great for 8 minutes or so at higher rpm's (under way) and then the rpm's begin dropping. They continue down until the boat is well off a plane (plowing through the water) and will keep running like this for a long time. After this happens, when the throttle is pulled back it runs very rough.
If it shut off for a long time (at least 30 minutes) it will start the cycle all over again. I have replaced the fuel filter, put in a temporary electric pump to a seperate fuel tank (to confirm I didn't have a fuel hose/pump/fuel delivery problem). I have replaced points and plugs, coils, plug wires, condenser, rotor and cap.
I have tried swapping props (to reduce the amount the engine has to push) to no avail. I should add here that we have lost track of the original prop, and have an aftermarket prop on. While I thought I was doomed with the prop change and losing the original, keep in mind that when the engine runs wellt the boat zips along just fine. It is after this specific amount of time when it acts up that the rpm's drop.
I have had this going on for two seasons now, and am very frustrated (as you might imagine after the list of trials and errors above!) I will appreciate any suggestions and will do my best to answer any questions. As Lake Superior is still frozen, I have a few weeks before it will be in the water!
Thanks in advance!
Bob T
Thanks in advance!
Bob T
