4.3 v6 hesitates when full throttle applied
BGutah
Hey all you boaters out ther;)...when I am pulling up skiers they hate me!:mad: because when I "hit it" the boat lunges forward..then hesitation and then goes....I think it may be the accelerator pump...I replaced the filter, no change so how tough is it to rebuild the carb on this engine? Any advice?...thanks:redface: and Hit It!
rndn
Re: 4.3 v6 hesitates when full throttle applied
It's not a big deal if you're mechanically inclined, if not leave it to the pros.
Welcome to the forum!!:)
imported_TheMan
It's as simple as buying a kit and CAREFULLY following the directions.
Did you replace all your filters? (the pump, carb, and water/fuel if you have it)
My mechanical fuel pump filter was chocked full of ... stuff....
superpop
This may or may not be a carb issue. On my 1996 VP 4.3L I had a bad module in the distributor that caused this problem. The problem was not the carb but the advance was way off. It caused hesitation and backfiring pops on hard acceleration.
Ayuh,..... Welcome Aboard BGutah,.......
It'll make it alittle easier to Help you if you mentioned just What Carb We're working on,..??....
As rndn says.... If you're a Wrench turnin' kinda Guy,.... It's a reasonably Easy Job,....
Equipment is the Big thing with rebuilding Carbs,....
Compressed Air is Mandatory,.... A Carb Soaktank it also a Big plus......
bsh21wash
I had this same problem on my 4.3 Had the carb rebuilt and the problem was gone.
180shabah
AS stated above we need to knoe what carb you have.
Liquid_force
mech or elect. ignition?
I have a similar condition when i don't get my points/condenser replaced at the correct interval.
I can go two seasons without much trouble. If it goes the 3rd I'll get the miss early in the season. Once I get them changed, problem's gone.
ccmarsh
If I were you I would rule out everything from the fuel pump to the carb before rebuilding it and even then it might not need rebuilt it might just be that the carb settings need some fine tuning. After all that if you still want to rebuild it's a lot simpler then people might tell you. First find out what carb you have. You can do this buy locating the list number on the carb. Then, buy the original manual was made when the carb was made(e-bay). Also, you need the correct rebuild kit. My carb is a two barrel but they also make a four barrel just like mine so when I ordered my kit I got the four barrel one. It's fine, just more confusing because there are extra gaskets and parts in it that you won't need. Next read the manual alot if you have to. familiarize yourself with the parts and when you believe your ready start the rebuild. Take your time, don't get distracted, and once you start it, finish it. Do not come back to it later. Have fun.
