I started up the engine for the first time today on a hose. Felt the riser getting hot and then checked temp gauge. It was 195 degrees. Replaced the T-stat (which was already done this month) and restarted the engine. With the engine at idle temp is now at 160 degrees. It used run cooler on the hose at 140 or less. The riser is heating up too. Cant keep my hand on it for more than a couple seconds. Valve cover is cool after running for some time. What is causing this?
The boat is run in salt water. Osco riser is new. Osco manifold 3 yrs old. Entire water pump/impeller replaced over the winter. Also had the engine out of the boat last week to replace the exhaust elbow which contains the flappers. New flappers installed. Ran cool when winterizing last fall. The manifold water passages where the riser bolts up are clear. What do you guys think?
