Hi, newbie here!
firehog6305
Re: Hi, newbie here!
welcome to iboats, that is a little big for I firat boat I think, but if you have been around boats all you life, like most people from florida have, then you know aliittle about them, good luck and keep us posted
fishmen111
Welcome! I love those older SeaRay cruisers. 7.4l Bravo...nice combo but hope ya got your Chevron stock handy. Good luck.
dave11
Beautiful boat. A trailer will cost nearly as much as the boat. It is almost as old as you. For a first boat I wouldn't get something that big and expensive to maintain. Think about getting a smaller boat with an outboard on a trailer. There will be fewer things to go wrong.
excellant boat. you have an advantage have a knowledgable friend. the motor has a good bit of rust, that is questionable.
Buying a boat
1st you need to decide what you want to use it for, fishing, cruising, or water sports.
2nd how many people adults, children you want on board of the average outing.
3rd outboard, inboard-outboard, or inboard power plant.
4th Budget, what you want to pay, and what you are willing to pay, when you find
Exactly what you want.
You can hire a marine surveyor, to inspect the boat, or you can do it yourself.
You are mainly looking for soft spots in the deck, transom, cracks, all signs of a rotten, under frame.
The motor should be clean, no spots where the paint is discolored, or pealing from heat, having run hot. Compression should be atleast 100psi, and within 10% of each other,
Spark on all cylinders, good pee stream, check lower unit for water in oil.
The overall condition of the boat will tell you a lot, as to how it has been maintained.
A 30 year old boat motor combo, may be in better condition, than a 3 year old.
n618ft
So I bought it - checked it out... better than I expected and I cant wait to start working on it. New AC, new bimini, new glass, full tank of gas! Any of you guys know if it's worth doing an HIN history report on it? If so, where/how in FL? :confused:
cbear34
Welcome to iboats!
Nice boat! Have fun with it.:)
oops!
good buy !
in canada that $20,000 bucks worth.
thats a whole lotta boat for a first time boat owner.....but thats ok.
yer in fla....the impulse to "take her on a good cruise" is gonna be considerable......please dont .....yet.
remember what happened to gilligan......
please take a safe boating course to start...then mabe a good power squadren.....
take a very experianced friend with you the first time you put it in the water.....if td's behind you in line to drop....he might introduce you to tasha :eek: :D.
....be safe....the captain of the vessel is responcible for all the souls on board !
have fun bud....any questions.....you know where to post !
cheers
oops
n618ft
Welcome to iboats!
I'm doing a fluid change on it before taking it to a different dock... where I'll smear it with some 3m compound an buff the heck out of it (not too much though - it's in pretty nice shape) then glaze it and wax it... taking all the wood off and any faded/cracked vinyl and reupholstering that and redoing the wood to a cherry-ish finish... then out of the water it'll come for new bottom paint.
I'm probably going to change the trim paint - that dark turquoise is nice but I could go for a black-on-white or all white w/ red trims... it also needs a cover. I want to put some beige w/ black berber in it too... should be a fun little project :D
n618ft
DEFINITELY... I've got some awesome friends that can help me out with this - and I'm actually going to share marina costs with them. I've already taken a safe boating course and I'm actually an airline pilot (doesn't translate well to boating but I can handle machinery lol).
you got an excellent deal. get the manual on the engine and outdrive. you may also want to have the outdrive pulled and serviced. gimbal bearing aligned, bellows check or just replace for peace of mine. nothing worse than worrying about bellow leaking. if it does not have 2 independent bilge pumps, one auto/manual and one manual. get it done.
