Re: Water Circulation 1971 85hp Johnson
lining up the tubes, mine has these little plastic tubes that you insert into the pump housing first, and they help to guide the metal tubes down into the assy. I did try putting the hose directly on the tubes going up and flushing the whole thing. The tubes going up seem to wiggle a little like they are loose on the top end, is that normal? The water escaping from the seam and small vent holes where the lower matches up to the lower leg also sprays out like it is under pressure, not sure if that is from the hose, or from the pump. One thing though is that the escaping water gets warm/hot as the motor heats up. sooooo it seems like the water is going up to the motor, but is not all going out the exaust? even if the exaust gasket is not sealing correctly to the lower, I would think that it would only seep into the rest of the lower, not escape under pressure like it is doing.
