halmc
Thread starter- Joined
- Feb 27, 2008
- 231
Mid eighties (guess) two stroke 40 hp Evinrude twin: Gorgeous blue spark at both plugs; 150# compression on both cylinders; Carbs clean as a whistle; Starts very weak, runs weak on one cylinder, occasionally hits very momentarily on the other. More than one set of new plugs tried w/o any change in symptoms. Fuel hose bulb pumped w/no change in symptoms. Momentarily actuating the primer from the control head (where the throttle/gearshift/ingition key is) produces just a bit stronger running. Removing the 'running' plug shows a plug fairly drenched with gasoline.
Any suggestions?
Another question: the fuel hose on the engine side of the connection to the engine runs back along the left side of the engine to some sort of a massive hunk of I don't know what. What is it? I see that there is a relatively small solenoid on the right side of the engine with a red sort of toggle switch on the side that is infact the 'primer' that permits the engine to suck in raw gasoline just at the very top of the intake on the carburetor, well down stream of the venturi. What's the correct position for the switch?
Thanks, Harold in Tallahassee, FL PS: I can gather up the model and serial number of the engine tomorrow if needs be.
PPS: what are the symptoms of a failed reed valve?
PPPS: are there electrical schematics anywhere on the 'net for this sort of engine?
TIA!!!
Any suggestions?
TIA!!!
