convincer253
- Joined
- Apr 3, 2008
- 7
I have a Merc 50 4cyl serial number 5797774 1980/81. My problem is the engine will only run with the choke on and will not idle. I've rebuilt the carbs/fuel pump/compression is 130 to 135 I've also ruled out primer bulb gas tank and connector. with it running I can spray carb cleaner everywhere without the engine rpm changing showing me there is no leaks. the guy that had it before me changed out the switch box and maybe the coils. I dont know where to go next....Help please!! Is there a way to do a static sync and link?
