WildBill79
Thread starter- Joined
- Feb 25, 2008
- 18
I can usually use the search buttom and get enough information about what I am doing without having to post a message but this time I am stuck. I have an 1986 Bayliner Capri with an 1986 85hp Force. The motor runs great and has never gave me any trouble. My boat didn't come with a tachometer so I decided to add one. I bought a 20 pole tachometer, wired the purple wire to the signal post, power to power, and ground to ground. When I turn the key, the tach moves to 0 but does not given me any reading when the motor is running. It just stays at 0. I checked the wiring at the motor and everything seems to be fine. Could the rectifier cause this? I also installed a volt gauge and when the motor is running it takes a while for the gauge to show 14 volts. It will stay at 12 for a while then eventually start creaping up. I checked the grounds on the motor and all seems well. Any idea?
Bill
Bill
