Re: no fire with plugs in 1975 Evinrude 85hp
Thanks for all of your help on this project I now believe I might be ready for the lake before the ice is off. I wonder what everyone did before Joe Reeves got a computer.
Okay here is were the engine sits as of now, I checked all wire cables and terminals all seemed good.
I took off the flywheel again and noticed a small amount of tarnish on the timer base sensors I dressed them with an emory cloth and put it back together I checked the spark with a tester and it readily jumped the 7/16 gap on all 4 I closed it up and it fired and started immedietly.
This boat sat untouched in a boathouse for over 20 years
To date I have cleaned both carbs, replaced all fuel lines under the cowl, replaced main fuel line and bulb, replaced fuel pump, replaced impeller, eliminated warm up stage of electric choke, replaced battery
While I was at it I followed the instructions on this site for installing a tell tale it turned out to be very easy and works well (I have the engine in a barrel).
Now the engine runs and idles very smoothly (I do not have a tach but it seems to be running at sufficent rpm for low idle) after idling a short time the engine will suddenly cough slightly and shut off, I hit the key and it starts right back up then after a while it will happen again. Where to from here? would this be timing? or carbs out of sync? I tried to do a link and sync but addmitedly have never done it before.
