I just purchased a used Motorguide Brute 756 and was wondering if anyone knows when they stopped manufacturing this model. Also, before mounting the motor to my boat I put it through a dry run using a single 12v battery and it seems to be running slower than I would have expected for 56# thrust. It has the 12/24 V option and the wiring configuration on a single battery is fairly simple so it shouldn't be the battery or the wiring causing the problem. The motor runs and all 5 speeds are working, but when I compare it to an old Minkota Endura (30# thrust) that I just sold its seems as though the Endura had a much higher RPM when the throttle was maxed. Any suggestions would be helpful.
