OD serial: OD732853
I'm having a heck of a time getting the preload set to the specified 5.25 in-lbs.
I needed to replace the yoke and seals on the drive shaft. After replacing the oil seal I put the gear and bearings back onto the old yoke to get a feel for tightening the nut to achieve the proper rolling torque.. I overtightened the nut and would up with a rolling torque of 10 in-lbs. No big deal, I needed to put on the new yoke anyway..
So I pressed off the bearings, and pressed them back on following the instructions in the manual. I put on the gear/bearing asm. on the new yoke and installed a new nut and tension washer. I tightened it finger tight and started checking the rolling torque. It was ~3 in -lbs. I turned the nut in 1/8 to 1/4 rotation increments and checked the rolling torque each time. When I got it to ~4.25 to 4.5 I tightened the nut just a hair more and the torque jumped to 6 in-lbs.
So now the plan is to press the whole thing apart again, and then back together and repeat. What's the trick? My plan is to get it to 4.25 to 4.5 again and then tighten 1/2 a hair and see if that works.
Also, the rolling torque is dependent on the rpm. the manual states after 2 full turns, take the reading on the 3rd revolution while turning slowly. How slow? 1 rev in 6 seconds? 1 rev in 10 seconds?
Last question, the bearings are pretty tight on the shaft. I can see over or under pressing the bearing farthest from the gear is a very easy thing to do. The manual states to press until the rollers make light contact with the cup. Is the remaining distance the bearing is supposed to travel down the gear shaft to be determined by tightening the nut? Or does the distance the bearing is pressed a thing you get a fell for after doing enough of them?
I know that when I stopped the press when the bearing rollers made light contact with the cup, there was still A LOT of play left...
Ryan
Ryan
