Re: 91 suzuki lower unit removal
Got the LU off (pretty easy).
I do have another ??? though. The drive shaft bearing housing will not come off. It feels as though their is "spring" tension on it. If I pry it up slightly, it pulls back down as soon as I release. To compound the issue, I tried to shift gears (had it in forward to remove the LU) thinking this may help free up the bearing plate... when I shifted up, I pulled the clutch shaft out!
Is their a trick to getting it back in the "ball mechanism"?
What's holding the drive shaft bearing plate (it cleared the gear case pin).
Thanks again
