Newb Powerhead Swap?
LARSON69
I'm new to boating and this site(awesome), and I recently purchased an old boat(one owner 1969 Larson 18' trihull shark) with a 1973 Johnson 115hp outboard. Previous owner said it got hot and has a bad piston. I pulled the plugs and the #1 looked silver and pretty beat up so I pulled the head off. The top of the piston is really chewed up like a piece of aluminum? The cylinder doesn't look that bad so I was wondering if I could just hone the cylinder and replace piston. Also, can I replace a piston without pulling the powerhead off? I also found another power head but I'm unsure if it will fit my unit. The replacement is a 1971 125 hp johnson/evenrude for about
$200. Can anyone give me some good advice. Thanks!
Re: Newb Powerhead Swap?
71 the splines are different, than the 73, 71 is set up for hydro-electric lower unit. 73 is a hydro-mechanical lower unit. you need 73-77.
rndn
Welcome to the forum LARSON69!!:):)
ezeke
As stated, you can't use the blocks before 1973 and the engines after 1973 are slightly different so you will need the whole powerhead if you use 1974-1977. The 1973 115, 135, or 85HP will work. The 85 has a different bore.
You will have to remove and tear the engine down completely to replace a piston. You will also have to find the cause of the meltdown and correct it.
LARSON69
Ok, thanks alot for the good info! :)
