Re: rectifier charges but tach doesn't work...
It can be bad and still charge, but start with the easiest. It is easiest to check for 12-volt power and proper ground first. A volt-ohmmeter or 12-volt test light are great tools for this procedure. Simply ground the meter or light, turn the key on and touch the positive probe to the purple wire on the back of the tach. You should see 12 volts indicated on the meter, or if you’re using a test light, its bulb should illuminate. Reverse the leads to check for proper ground, or use the ground wire on the tach to ground your meter or test light.
If either the power circuit or ground is the culprit, you can repair the problem and the tach should work fine. In a no-power situation, see if your tach has an inline fuse. These often blow due to constant vibration. After inspecting for power and ground, if it still doesn’t work, it’s time to check the signal-input source, or the tach itself.
A simple way to determine if the tach is bad is to use another tach. This you tried by buying new.
In the event you don’t have access to a new tach, you’ll have to refer to the manual to check the signal source. The signal is a pulse-positive output that’s provided directly from the stator assembly through the rectifier. A peak-reading voltmeter set to “positive” and the lowest volt scale will enable you to read any voltage output (on this circuit) from the stator.
Check the procedure and specifications for your engine, since the inspection point, procedure and wiring are not the same for all outboards. In addition, your ohmmeter can be used to check the continuity of the stator windings, as well as the integrity of the rectifier diodes.
If everything still checks out, you will need to re test your rectifier/regulator as per your manual. What exact test did you do to test it? What were the readings?
These pages may help
http://ww2.tflx.com/pdf/obtach~1.pdf
http://ww2.tflx.com/PDF/99320.pdf
