ejs_developer
Thread starter- Joined
- Apr 10, 2008
- 2
I'm having surging/power issues while running my engine at high speeds. The engine runs fast for a few minutes, then starts to run very slow and bog down, then fast again, and then slow again. At low speeds it seems to run fine. The odd thing is that the problem occurs mostly early in the morning. In the afternoon, after I have run the boat for awhile, I don't experience the problem. I have read through similar forums, but I am not sure what the issue is.
Note: I inspected the hand pump/bulb with the engine off and it looks good and is pumping fine. I have not yet checked the hand pump/bulb while the engine is running.
Does this sound like a fuel issue or some other issue?
If fuel related, should I change my fuel pump, fuel filter, etc.?
Thank you,
Ed
Thank you,
Ed
