I have two questions to ask, both regard tow vehicles to move my 28 foot sailboat (6800# plus galvenized steel trailer 3000# according to the title, I bought the trailer last winter and have only pulled it empty for 250 miles). The marinia where I keep my boat has a travel lift so pulling up a ramp is probably a non issue. My main towing need will be from my house to the marina which is about 50 miles on mostly flat roads, either bringing it home to work on over the winter or running from a hurricane. At this point in time I don't own a suitable tow vehcle, but have use of two potential ones any time I need them.
Choice #1
1999 GMC 2500 Conversion Van with towing package I think the engine is a 5.8 V8, automatic I have used this van to pick up the empty trailer, and also once pulling a 16 ft trailer with a 5,000+# peice of equipment on a 12+ hour drive. That drive was not fun, it was foot on the floor all the way, and it would take about 2 miles to get up to 65mph from a stop. This van has about 100,000 highway miles and is in very good condition. (needs electric brake control)
Choice #2
1994 Dodge 2500 short bed pickup with 5.9 Cummins Turbo diesel automatic transmission (older 12 valve model) set up for heavy duty towing, 250,000 miles, semi retired farm work truck, rough condition, engine runs rough until warmed up, turbo bearing has slight squeal, transmission seems ok, but who knows, set up with electric brake control.
I know the Dodge would seem like the first choice, but could a 10,000 pound load potentially cause turbo failure, etc. on the already squealing turbo, etc?
Topic Number 2
I can get a 1992 model Ford F-250 long bed, ext cab Diesel pickup for free, the good news is the transmission is in good shape (or at least had a lot of money spent on it just before the truck stopped being used), and there are no major body problem, that is the extent of the good news. The bad news is the engine is shot, and in peices, it needs new tires, and brakes need work along with new read side windows and windshield, who knows what else. I think the engine is the 6.3 IH pre Powerstroke non turbo. If you were setting this truck up as a tow vehicle/general use pick up for hauling stuff what would you do, and what engine would you use?
Thanks Ike
Choice #1
Choice #2
Topic Number 2
Thanks Ike
