Testing for spark
mav6759
Quick, question I want to check the spark from my coil, but I'm by myself and can't turn the key and hold the screwdriver too. Does anyone know of a way to do this when theirs only one person.
mav6759
Re: Testing for spark
a remote started switch that clips on the starter solenoid. auto parts store. while you are there get a proper spark tester.
Jill_S
Sorry to butt in but whats a "Spark tester" how does it work.
Thanks
Jill
Jill_S
Thanks...I'll be adding one of those to my boating tool box.
I'm testing my attachment skills to see if I can post a picture. Found an appropriate pic of a plug.
Jill_S
It works...:)
HighTrim
The adjustable ones are much better as you can assure that you are jumping a minimal gap for proper firing.
For larger HP motors, the multi way testers are nice as you can visualize the difference in spark between cylinders simultaneously. They can also be used in conjunction with a compression gauge when testing compression instead of grounding out the leads.
Mavs make sure your spark is jumping a good 7/16 of an inch with a bright blue ZAP!!
