sand in the water pump
Hobiecat16
I have a 1996 130hp Johnson ...The water pump keeps getting filled with sand. Its used in the bay and inlets and sometimes theres no way around shallow water. Every 4-5 trips I have to drop the lower unit and clean out the hard packed sand. After cleaning it out it runs great and doesnt over heat ...till I hit sandy bottom again ...any sugestions on how to prevent this..
Solittle
Re: sand in the water pump
Welcome Mr. Hobie - The symptoms you describe point to the helm as the source of the problem and the guy (or gal at it).
Hobiecat16
how did i know I would get those type of responces ....Maybe I'll try to paddle across the sand bars ...
Dhadley
We're faced with the same problems here when fishing the flats. The vast majority of flats boats have a hydraulic jackplate to get the lower unit as high up as possible when we need to. I ran in some places yesterday that if I stopped, I'd be stuck.
Trimming up is one thing but going vertical is what helps the most.
