Re: telltale pressure?
hey dawgs did you get the lower off, i dont know what it should be with a gauge .but you also need to check your thermos and poppett valve s
you should have a steady strong flow from your telltale .
and be able to keep your hand on each head for a few seconds.
the problem with water pumps is they may be pumping good now
but if they are dryrotted or burnt they will go out on the drop of the hat and
in my case by the time my buzzer whent off it cost me a cyl .
if you decide to run it for awhile .keep a good eye on the tale tell
or better yet put a water pressure gauge on so you can keep and eye on it.
my bad if thats what you are doing .i thought you may be checking the pressure with gauge then removeing.sorry i couldnt be more of help with the stuck lower .they are and can be a major pain,if there is a good outboard guy around your area you may be strait with him and tell him its stuck and see
what kind of price he throws you.my outboard guy told me to bring him mine
before i tried to remove it.and he would do it for 250 with new pump
i wish i would have . i almost gave up.
i would have put gauge on mine and ran it thru the summer but it was peeing real weak and my buzzer whent off at the lauch so i had no choice
good luck dawgs you will get it done
Bennyb
