Buy the way thanks to both of you on the starting lesson, it fired up just like you both explained. I need to put a water pump in the motor because it just a safety measure for just buying the boat. Normally how hot is the water suppost to be out of the pee tube. I can hold my hand under it for about 3 seconds and its hot all the time running. The lake temp where I've been running it for testing before a long haul is 65 degrees. Also, from past experience it shouldn't take a couple of mins to start peeing out of the tube on first start should it?
