purchasing used outboard, advice please!
chattyrona
Tomorrow we are looking at a 1984 60hp Johnson outboard. We really think it would be great for our old Glasspar Tacoma. The guy replaced this engine with a new 4 stroke and he says it ran fine. It includes the throttle cables and he is asking $750.00 is this a fair price or is there some kind of price value book for used motors? Any advice would be great, we are scared to spend this kind of money unless it of course was surely to work, then it would be great. We have never purchased anything for a boat before, and all our friends are not familiar with outboards especially old outboards. Thanks for any helpful info!
Re: purchasing used outboard, advice please!
Look at it this way -- If you can't hear it run, you have absolutely no idea what condition it's in. About all you can do is hook up a battery and at least do a compression check. Better yet, get it writting that if you get this engine installed on a boat and it fails to run, the seller fixes it. That said, $750 sounds reasonable but we cannot see the motor. I would want some sort of signed document if I can't hear and see it run. Taking someones word for it is a sure way to get burned. You don't buy a car without a test drive (do you??) and you should not buy an engine that way either.
agree, do the controls, wiring harness come with it?? they should.
jbjennings
I totally agree with the above. Also, I know some folks have plenty of money and wisely replace their outboards after 7 or 8 years of use just to be reasonably safe from breakdowns. Then again, most folks don't have plenty of money and don't replace an outboard unless it's having some kind of problem. If you can work on it, you can get a good deal from the latter because the problem may be a very cheap fix. It also could be an expensive fix, like lower unit gear/clutch dog problems or electrical problems, particularly if you have to hire a mechanic to do it for you. You should be able to tell when you drive up to the guy's house which one it is and how well he takes care of his stuff. I'd want to see it run on muffs at least. I'd also want to do a compression check. A tester is only about 20 bucks at the local autoparts store and all you do is take out all spark plugs, screw the tester into each cylinder one at a time and turn the engine over till you get the highest reading on the tester's gauge. All cylinders should be very close to one another. If there's one cylinder that's quite a bit different from the others, don't buy it because the powerhead is no good. You really can't check the lower unit for anything but water and whether it actually shifts onless you run it on the boat. That's when you find out if it slips out of gear or not. There's no book that's any good for prices on stuff that "old". If it looks really nice with no scratches and the skeg looks nice with no dings/ deep scratches that's a good sign. The prop is also something to look at. Turn it and make sure all the blades are nice and true. The boat it came off of is also a good indicator of the kind of use it's had.
Just a few thoughts,
JBJ
