Ok, my 1998 50HP outboard johnson started leaking lower end fluid out from where the prop enters the lower unit. This was the first time I started the motor this spring(started, idled, put in gear for a minute, shut off, ran a total of 5 minutes), just pulled it out of the storage. I have never seen it leak from this location before. The fluid was a solid black, was NOT milky. I pulled of the prop and the anode piece and found a lot of fishing line ran around the shaft.
Where could the fluid be coming from? How do I troubleshoot to find the leak. Does anyone have a diagram or picture of where the seals are or how to replace them?
It would be nice to find a pictoral HOW-TO online if its possible.
Thanks!
Thanks!
