Hello!
I got this boat last year, and started working on it for this summer.
It's a 150 ser 0G028824 .
Up to now I put new plugs, new set of wires , new t-stats , took out the carbs and checked to see if there is any gunk or if they are dirty, they were clean used air pressure , blowed all jets and passages put new gaskets and put'em back.
The engine runs exactly the same as before I did all this, first time I started it.
I'm running from a gallon size can since I have to clean the tanks of the old gas.I'm running premix 50:1 to the fuel pump, removed the oil injector.
the engine idles ok but if you're trying to go higher in rpm's it goes rough.
sounds like it's missing on one or more cyl's .
I can't get it over 3k or it will fall apart, vibrates and sounds rough.
I installed a fuel pressure gauge in between the fuel pump and the first carb and I have about 4psi at idle and it goes up a bit when you give it some gas.
Never drops under 3 psi. I'm wondering if this a good pressure or not!!
I removed wire by wire at the plugs and they seem to fire all, I can notice the diference with the wire removed.
What's next.
I made a video with my cellphone with the engine running , I don't know if you maverick mechanics out there can figure out what's going on just by watching this video or listening to the engine.
Here's the link:
http://64.65.22.75/movies/nitro/v150.wmv
It's about 13mb. I will try to make a better one where you can hear the engine better.
Any input is appreciated.
Thanks
What's next.
Here's the link:
Thanks
