krisnowicki
- Joined
- Jul 11, 2007
- 1,172
lost about 40 hp in my motor switch from the vortec 350. I was running a 14.5 x 21 inch prop. Today when I went out i was using the same prop. When I go to WOT off from idle she revs up to about 2300 then sits there for about 20 secs until it gets on plane. Then it will go up to about 3300 and thats it. When it is not under load it will rev and hold up to 5500 but i never do that. Also since my when it is not under load I can see the tach show the 650 idle to 5500 with no jumping the tach has to be right. Also, I was doing about 30 mph (29.2 gps)at 2300 with a 21p prop. This computes with the prop calc. So my questions are, 1. Is this typical behavior of a boat that is way over proped? 2.if so is the 21 to 19 jump going to be enough or should I go to a 17? I do tubing and cruising. 3. If not what would cause this to happen.?
