Steering cable for 65 hp Evinrude
eterry
I am not sure if this is the right forum, but if not it will be moved. A co-worker is looking at a boat with a 65 hp evinrude. The owner says it needs a tune up and the steering cable is broke. How much time/trouble/money is involved in replacing a steering cable on that size motor? Is there any maintenance that I should be doing to my steering cable? It looks old but it works.
Thanks
Eterry
F_R
Re: Steering cable for 65 hp Evinrude
Depends on whether you can get it out of the tilt tube without removing the motor from the boat. Also depends on how deeply it is buried in the boat and how much stuff the installer bundled to it. Can be fairly easy, or can be fairly difficult.
eterry
Thanks FR, will pass on the info. Is there anything I can do for my cable, maintenance wise ? Just dont wanna have to replace mine any sooner that needed.
Eterry
ksubigbuck
Eterry
Greasing it sure wouldn't hurt! I think they usually get stuck after sitting without use for long periods of time. It might be a good idea to crank your steering wheel full port and full starboard every once in a while when you are out in the garage.
F_R
Regular preventative maintenance demands that the cable be kept lubricated where it slides in and out of the tilt tube. Ignore it and the tube rusts inside and locks up the cable. Then you REALLY have trouble.
eterry
Thanks for the tip guys, will try both and see how long i can make the cable last.
