swrupert83
- Joined
- Mar 20, 2008
- 51
so i'm about to take this engine on a one way trip to the middle of vineyard sound.
1985 85hp so far replaced the starter solenoid, the starter, the prop (huge chip in it), and the fuel line; also pulled and cleaned most of the terminals. Went to fire it up for the first time (which by the way I can't for the life of me find "ear muffs" that fit, so i just bought a big rubbermade container and filled it with water). At first the solenoid for the choke didn't work but after jumping the switch once, pushing in the switch (key) made it engage almost every time. She just cranked and cranked, but nothing, then a BIG backfire(?). I pulled the plugs, 1 & 3 where black, so i sanded down lightly with emery cloth put it back together, sprayed 50:1 (with a drop of sea foam in it) into the carbs. I noticed that, when out of gear, the control doesn't let you open full throttle or for that matter any sort of open. cranked again, she kinda started but not really...... I could hear the engine pick up faster than the starter, but as soon as I let off the starter, she stopped. (fyi i did check for spark, 2 & 3 have a strong spark, 1's spark is weaker)
ran the battery dry, set it up on the charger & went to waxing the boat.
with a full charge hours later, I start the whole thing again. again with the almost starting and back-firing
THEN i went to crank again, and my brand new starter made this horrible ratchet noise. upon futher inspection I notice that the starter is spinning but the head with the teeth is not. the fly wheel turns easily enough by hand
any suggestions... kinda know two that are gonna come: rebuild carbs, do compression check.
