my engine dont start anny more
hoi david from belgium its abbout een crestion for my friend,hy haf one bayliner from 1998 with a mercruiser 4.3 v6 151 kw with alfa one drive.now the problem is dat de engine dont start anny more hese had scarry noise in the middle of the engine en arrond the drive schaft . what can this problem are?
i am sorry for my bad englisch
greets david
Haut Medoc
Re: my engine dont start anny more
Welcome to iboats.....:)
Is it making the scary noise when you turn the key & the starter engages?.....:confused:
Ayuh,....... Welcome Aboard,...... Your English is reasonably Easy to read.......
You'll need to describe what's going on alittle better though......
At this point I'd Guess that your Starter is Falling Off.........
Don S
Remove the starter, and inspect the gear teeth on the starter and the flywheel on the engine. I would suspect broken and missing teeth on the gears.
