4.3 Merc won't fire up
mseymour
I have 1988 4.3 liter mercruiser with a Gen I alpha outdrive. I have replaced the starter, distributor cap, rotor, and ignition sensor. It will crank, but won't fire up. I have tried starter fluid and it just spits and sputters. I have checked and rechecked the timing, and I am sure that everything is right. Any help would be greatly appreciated.
Bt Doctur
Re: 4.3 Merc won't fire up
Lose the starting fluid or lose as piston,a little bit of gas in a squirt bottle is better.
Do you have GOOD SPARK, check with the coil wire 1/2 from the block.
Did you mix up the plug wires or did you do 1 at a time.
Fuel condition and quantity?
You cant check engine timing unless it running,so what timing did you check?
Ayuh,...... Welcome Aboard,........
What BD says,......
mseymour
I did not mean timing, I meant firing order in terms of plug wires. I am certain the wires are in the right order. I have good spark all the way to the plugs. Gas is brand new, 87 octane, shell.
Don S
Did it run ok BEFORE you did all that work to it?
Do me a favor, and count the openings in the rotor and let me know how many you have.
If All 6 Plugs are Firing,...
Can you See gas squirting into the Carb, when the throttle is pumped,..??
