Re: prop size
That is a hard question to answer without a little more info.
One of the main goals in prop selection is to determine what prop style and size will maximize performance for your boat, while allowing your engine to operate in the recommended RPM range. The correct prop will prevent the engine from over-revving, yet at the same time allow it to reach the minimum RPM where maximum horsepower is produced.
What is your current WOT RPM? Depending on the motor they should be around 5800 to 6200 RPM with todays fuel. If your test results in your being able to over-rev the engine, you need to increase the pitch of the propeller. Increasing the pitch increment by 1" will result in approximately a 200 RPM drop.
Once your wide open throttle RPM falls within the recommended range of the engine manufacturer, you have a propeller that is suited correctly for your boat, with respect to RPM that is.
You may need 2 props, depending on the activities that you do. Bottom line though is that it is CRUCIAL that the WOT RPM fall within the reccomended specs.
